This is a non-profit website. We dont even have those annoying advertisement. We tried our best to help anyone that has question about H. pylori. We provide the most accurate answer about H. pylori. You can help us by clicking here donating to keep our forum alive.
Yet another h.pylori infectee
sparklypickle
Re: Yet another h.pylori infectee
Post by sparklypickle » Thu Sep 03, 2015 10:50 pm
Test came back negative (one week after end of ab course)....so....not sure where that leaves me. I'm feeling slightly less dreadful today so hopefully that means that I'm on the mend? Time to bring out the valium and probiotics I think.
Post by Helico_expert » Fri Sep 04, 2015 9:36 am
Congratulation! I think you just need to gather positive thoughts and give your stomach some time to heal.
sparklypickle
Post by sparklypickle » Fri Sep 04, 2015 2:14 pm
Thanks! Having a positive voice of support really makes a difference :) did you see my Scientific questions in the last post?
Post by Helico_expert » Mon Sep 07, 2015 1:18 pm
sorry i missed your questions.
In terms of work related antibiotic resistance, I think that depends on your aseptic technique. If you did it correctly, you should be contaminated with laboratory antibiotics induced resistance.
In terms of iron deficiency, H. pylori is associate with low iron deficiency. Some patients' iron level return to normal after eradication of H. pylori. The mechanism is unknown, but it works for some people.
in terms of antibiotic resistance pattern, each country is different. In Australia, most of our strains are resistant to Clarithromycin (>90%) and Metronidazole (>60%). In China, the Metronidazole resistance is as high as 90%.
read our paper, there is a table display resistance in Australia
http://onlinelibrary.wiley.com/doi/10.1 ... 12089/full
Read this paper, there is a table display reistance in China
http://onlinelibrary.wiley.com/doi/10.1 ... 12046/full
In terms of tetracycline, we havent really seen one strain that has resistance to Tet. This antibiotic targets the 16s rRNA. The gene is probably too conserve and too costly to mutate. There are reports of Tetracycline resistant H. pylori strains. But we have not seen one.
sparklypickle
Post by sparklypickle » Mon Sep 07, 2015 3:40 pm
Thanks helico_expert :) that's interesting. I will have a look at those papers.
I think my sterile technique is good because I very rarely get contamination when working without antibiotics, I just wondered if in general there were more ab resistant strains kicking about in a lab.
Ooh the fact that tetracycline affects the ribosome brings me to another question...how is helicobacter able to mutate so much faster than most other bacterial strains? Does It have really poor proofreading in its DNA polymerase?
Post by Helico_expert » Tue Sep 08, 2015 10:01 am
In the lab, you should be constantly spraying alcohol to avoid contamination of bacteria. Nevertheless, even the top rank laboratories are spreading HeLa cells everywhere. read the story here
http://berkeleysciencereview.com/article/good-bad-hela/
in regards to H. pylori's mutation, yes, H. pylori lack of the proof reading function in the polymerase. So every time it multiply, it makes a little error. We sequenced the genome of H. pylori of 3 passages and there, accumulated at least 2 SNPs. However, when you put H. pylori into a new hosts (eg. Mouse), then passage in agars, you'll see over 1000 SNPs. So the mutation rate is also related to stress and environment change.
can read this paper.
http://www.nature.com/ncomms/2014/14061 ... s5165.html
sparklypickle
Post by sparklypickle » Fri Nov 13, 2015 5:14 pm
Hello. My followup test at 6 weeks post treatment was negative so I started to taper off omeprazole and the prebiotic I had started taking. Starting from 40mg daily Omeprazole at 20mg.per day was fine, 20mg every other day was a bit suboptimal but leaving it three or four days between doses is horrible.The problem is, I'm now having a horrible sensation in my stomach and upper intestines like they are constantly burning or something. Antacids do nothing to relieve it. I've also reverted to my previous bowel habits of loose stools in the morning and hard ones at night...neither are normal and I feel kind of queasy. I was up at 3am with crippling gas pains last night too :( I will go to the Dr next week to discuss because I feel like my digestive system is really unhappy about something. I still can't look at orange juice, coffee or alcohol.
Post by Helico_expert » Wed Nov 18, 2015 3:49 pm
hi, just want to make sure that when you did your followup test, you are not taking any PPI or antibiotics for at least 2 weeks. Any drugs that reduce your stomach acid will give you a negative breath/stool test.
Nevertheless, assuming that you did the test correctly and truly now free of H. pylori, perhaps you need to speak to a dietitian or immulogist to check if you are allergy to certain food.
sparklypickle
Post by sparklypickle » Thu Nov 19, 2015 3:09 pm
Hi, I only stopped ppi for two days as that is what my Dr advised, but it was 6 weeks after abs. I've been told to continue ppis for the foreseeable future because my stomach is still overproducing acid, and Dr thinks I have ibs...I'm being referred to a dietician and also for counselling as it is very likely due to anxiety. I think my helicobacter journey is over but it's just annoying that my stomach is not how it used to be despite an apparent eradication. If I ever manage to come off omeprazole then I may ask for anothr test to be sure.
Post by Helico_expert » Thu Nov 19, 2015 3:58 pm
there are many ways of stopping acid production. Some has strong and long lasting effect and some have shorter effect. For people who needs to do UBT or stool test, it is better to use the short effect life drugs.
Please refer to the reference table from the link below to choose your acid inhibitor before your next testing.
