This is a non-profit website. We will try our best to help anyone that has question about H. pylori and their treatment. We shall provide the most accurate answer about H. pylori. You can help us by clicking here to help keep this forum alive.
How to post in the forum
Breath test in Perth
Sam
Post by Sam » Sun Aug 05, 2012 10:28 am
Hi I live in Perth and would like to get a breath test. I would like to know where I can go for the breath test?
Thanks Sam
User avatar
barjammar
Re: Breath test in Perth
Post by barjammar » Sun Aug 05, 2012 9:55 pm
All Perth labs do the urea breath test. Any GP can order it for you. Results usually come back in 3 days.
fruitlover
Post by fruitlover » Fri Aug 10, 2012 3:48 pm
Yes, Perth Labs would help. They provide a wide array of tests and services related to breath. You may want to try other laboratories but call them first for schedule.
tysonlee
Post by tysonlee » Wed Oct 17, 2012 3:02 pm
Test king http://www.testking.org/
Training 640-461 http://www.testking.org/640-461.htm
Exams 000-780 http://www.testking.org/000-780.htm
Material 70-646 http://www.testking.org/70-646.htm
Post by Helico_expert » Wed Oct 17, 2012 10:10 pm
any gp will be able to order a breath test for you.
ANJUL
Post by ANJUL » Fri May 09, 2014 3:48 pm
My experience has been that it is virtually impossible to get the C13 urea breath test in Perth. C14 yes, C13 no.
I was diagnosed with HP via a blood test ordered by my GP after reporting a bout of vomiting (unusual for me, last one 30 years ago!). GP told me I needed a blood test to determine if I had HP (I wasn’t told what that was) If yes, I would take a course of antibiotics to eradicate the bacteria, then if necessary, a carbon urea breath test. After investigation, I found there are two breath tests - c13 and c14. The c13 urea is a stable (non-radioactive) isotope, the c14 is radioactive (although, I was told, in minute quantity). Both require overnight fasting before the breath test is carried out, although even for this I got conflicting information by labs - one said I had to fast overnight, another for 4-6 hours whatever the time. One said I could drink water, the other said no water. I am confused.
But the best confusion came when I asked for the non-radioactive C13. I explained my reasons for not wanting radioactivity (previous cancer with radiation therapy) but was told that c13 is not available in WA due to cost (see below). One contact suggested I see a gastroenterologist, another to find a private lab. Some labs were not even aware there was another test available.
Re cost, I checked with Medicare Perth who advises both C13 and C14 (item no. 12533) cost the same - scheduled fee $84.65 of which Medicare pays 85%. My question is can we have the C13 in Perth and if yes, where?
Post by Helico_expert » Mon May 12, 2014 9:30 am
It is a bit rare for C13 breath test in Australia. However it is not impossible. You just need to find really hard in google for a supplier of C13 then ask them which GP or lab they supply to.
