This is a non-profit website. We dont even have those annoying advertisement. We tried our best to help anyone that has question about H. pylori. We provide the most accurate answer about H. pylori. You can help us by clicking here donating to keep our forum alive.
UBT Testing equipment
chritvas
Post by chritvas » Mon Aug 16, 2010 4:54 pm
Hi!
I intent to buy Hp testing equipment C13 for my clinic. Can anyone advice which brand should I buy? Does anyone know about the China Brand Richen Force?
With many thanks
Chrit
kylie
Re: UBT Testing equipment
Post by kylie » Thu Aug 26, 2010 12:46 pm
Dear Chritvas,
I recommand you to buy Richen-force‘s IR-force 200 for your clinic. Compared to other brands, it is cost-effective. Its owner: Mr Gong Aihua, has been dedicated to the breath test field since 1998, who is very familiar with this project. The IR-force 200 is at its fourth generation, you can see its technology is very advance.
Well, you may ask why I know so much. Because I am the International Manager of this company. For more information, pls log on our website.
Good luck!
Kylie
User avatar
luci2010
Post by luci2010 » Thu Aug 26, 2010 6:43 pm
The most common Urea breath test used in UK is http://www.infai.co.uk/products/helicobacter.php
You might want to check it out.
Kind regards,
Luci.
Please check the FAQ. If you haven't tried it yet, click here, and look inside the FAQ's. Your question might already be answered.
User avatar
barjammar
Post by barjammar » Mon Feb 07, 2011 9:55 pm
I don't see any discussion about C14 urea breath tests here so I need to provide balance. The PYtest, marketed worldwide by Tri-Med and manufactured now by Kimberly Clark in Utah USA, is still the most cost effective. The tracer of C14 is so trivial that it is has been used freely in the USA for about 14 years now. For laboratories, several people can do the test at once. A very accurate machine called the "Microcount" makes reading the test foolproof. To find out how to get it, contact Tri-Med Distributors via the website at http://www.trimed.com.au. 8-)
