若有困难注册,请联络站长
Helicobacter and CA72-4 Test
Laura32
Post by Laura32 » Tue Apr 24, 2018 8:07 pm
Hello
I got Helicobacter IGG result 5.3 and Helicobacter ELISA test result 339 - from blood tests
Also got CA72 -4 Result 45 (normal should be >6)
Stomach camera test showed all fine - only one erosion
Can CA72 - 4 be increased because of Helicobacteri in stomach and blood????
Thank you
Re: Helicobacter and CA72-4 Test
Post by Helico_expert » Tue Apr 24, 2018 11:03 pm
Ca72-4 is a cancer marker. I am not familiar with the mechanism. Perhaps there is a reason your doctor order that test on you. Can check with him.
Nevertheless, if your stomach is clean. Only an erosion, there is no need to be worried. Most important is to make sure you have HP eradicated.
Laura32
Post by Laura32 » Wed Apr 25, 2018 3:37 am
Thank you
