若有困难注册,请联络站长
Fasting longer & C13 test result
Adam
Post by Adam » Wed Jun 05, 2019 4:07 am
Would fasting longer than the recommended time, affect C13 test result?
Re: Fasting longer & C13 test result
Post by Helico_expert » Wed Jun 05, 2019 9:19 am
nope. as long as your stomach is empty, then only we can confirm that the breath test is reacting on the bacteria, not your food.
