若有困难注册,请联络站长
Does this therapy work??
cyprian zimunya
Post by cyprian zimunya » Sun May 12, 2019 4:52 pm
I want to ask that does this therapy more effective to eradicate h pylori.. amox ig three times a day ,bismuth 120mg three times a day , metronidazole 200mg three times a day and esomeprazole 40mg 2 times a day... my main voncern is on metronidazole i have used it before so it might not work ..furazolidone is not widely spread in my country so i might not able to get it ..so is there other antibiotic that i can use instead of metronidazole or i can just use metronidazole since i heard you saying that metronidazole resistance can be overcomed when using another strong antibiotic
Re: Does this therapy work??
Post by Helico_expert » Sun May 12, 2019 9:56 pm
High dose PPI + High dose Amox + Bismuth may already give you a cure rate of 80%.
Metronidazole resistance has been shown to be able to be overcome when used with Tetracycline. Since The H. pylori will not become resistant to Amox and Bismuth, I think you can give this quadruple (PPI + Amox + Bismuth + Metro) a try.
If it failed, you can always repeat PPI + Amox + Bismuth + one other antibiotic.
cyprian zimunya
Post by cyprian zimunya » Mon May 13, 2019 1:58 am
Ok i will take your recommendation thanks. What about if it failed what other antibiotic should i add there?...is tetracycline and amox the same or is it possible to add tetracycline there or i should not add it ,it will reduce the effectiveness of amox
Post by Helico_expert » Mon May 13, 2019 8:40 am
very good question. In theory, Amox and Tetracycline should counter each other. But in practical they dont. I am not sure why.
So, Yes, tetracycline can be your next choice if your current therapy failed.
cyprian zimunya
Post by cyprian zimunya » Mon May 13, 2019 10:05 am
Ok thanks so i can include tetracycline in my therapy if it failed ..so it will be amox,bismuth, tetracycline and ppi
Post by Helico_expert » Mon May 13, 2019 10:40 am
Yes. But hopefully your PBAM will work and you dont have to try PBAT.
cyprian zimunya
Post by cyprian zimunya » Mon May 13, 2019 11:16 pm
Lets hope it will work i will talk to my doctor about. Is it possible to increase omeprazole dosage to 40mg twice a day
Post by Helico_expert » Tue May 14, 2019 9:17 am
yup. you can do 40mg twice a day.
cyprian zimunya
Post by cyprian zimunya » Sat Jun 29, 2019 1:40 pm
I finished my antiniotics for h pylori four weeks ago ,since then i was on ppi but there are no changes yet ,should i start worrying or give my stomach time to heal . I have chronic gastritis and h pylori
Post by Helico_expert » Sat Jun 29, 2019 10:30 pm
You can gradually stop your PPI.
switch to one tablet a day or a tablet every two days.
