It all started back in early October. I was on holiday with my girlfriend when I began to get stomach ache in my upper left abdomen and behind the lower ribs and loose stools shortly after arriving there. I chalked it down to probably having some bad food whilst there and thought nothing of it. That is until I continued to get stomach ache and loose stools after we returned home.
I had had something similar a year prior that resulted in my doctor prescribing me anti diarrhoea tablets which seemed to clear it all up after a couple of weeks. Thinking it was something similar, I booked myself in to see the doctor.
He felt around my stomach, didn’t feel anything weird and prescribed me with hyoscine butylbromid and sent me for a stool test. The stool test came back clear but my stomach was still aching so I went back to the doctors at the end of October.
This time round they sent me for a full blood count and another stool sample. The stool sample came back clear once again, as did the blood tests. The doctor prescribed me ranitidine and sent me for a helicobacter breath test where the earliest I could get in was 2 weeks after the appointment. It wasn’t until the end of November that I was able to have the test and get my results back, testing positive for h pylori.
The doctor prescribed me metronidazole (400mg) and clarithromycin (500mg) for 1 week and lansoprazole (30mg) for 2 weeks – this is nearly 9 weeks since the symptoms began. I began the take the medication and it seemed to really help with my symptoms. The stomach ache reduced drastically and I thought I was on the mend.
However, around the 14th of January (nearly a week after finishing all my meds), my stomach ache began to return, going from aching every other day to being every day. Once again, I returned to the doctors, who felt around my stomach briefly and then prescribed 4 more weeks of lansoprazole and said nothing more. Taking these reduced my pain again and I thought I was finally going to be over it. No such luck.
I finished the lansoprazole around mid-February but the stomach ache once again returned around a week after I stopped the lansoprazole. Since I wasn’t able to get to a doctors, I went to my local pharmacy and told them about my symptoms – they gave me some nexium, but told me that the doctors should have booked me in for another breath test to make sure the h plyori had gone. Ringing my doctors, they said that yes, I should have been retested and booked me one in which I took this Tuesday. However, between the time of them booking me in and then taking the test, I had really bad stomach ache. The pain has mostly always been in the same place – upper left stomach, just below and behind the ribs, but it’s also started to ache round the back and up towards the left shoulder. I went for an emergency doctors appointment, who prescribed me more ranitidine (150mg) and said I had to wait for the test.
Does ranitidine effect a breath test? I’m scared I’m going to get a false negative etc.
I didn’t take any the night before the test and only started taking them again last night as my stomach ache started to return and I began to feel really tired and a little light headed. I’m really scared it’s something bad.
Is this h plyori still or something more sinister?
Re: Is this h plyori still or something more sinister?
For a breath test you should stop ppi for at least 2 weeks as far as i know, but ranitidine you can take without problems. About your symptoms it happened the same with me, after a week or so i started to feel ill again, and in fact, i am still h pylori positive.
Hey thanks for replying and sorry to hear you're still feeling illNoxArcana wrote: ↑Thu Mar 28, 2019 9:44 pmFor a breath test you should stop ppi for at least 2 weeks as far as i know, but ranitidine you can take without problems. About your symptoms it happened the same with me, after a week or so i started to feel ill again, and in fact, i am still h pylori positive.
I knew the PPI's had to be stopped 2 weeks before the test, but was unsure about ranitidine as the NHS website said you should stop 3 days before the test.
Have you been prescribed anything to help you kill the h pylori?
Would the PPI's and ranitidine cause the symptoms to subside whilst you take them?
I did two different triple therapy, both failed. PPI help with the symptoms, but they do not go away completely if the h pyori wasnt erradicated, you need to take the test to confirm.redheadj wrote: ↑Thu Mar 28, 2019 10:28 pmHave you been prescribed anything to help you kill the h pylori?NoxArcana wrote: ↑Thu Mar 28, 2019 9:44 pmFor a breath test you should stop ppi for at least 2 weeks as far as i know, but ranitidine you can take without problems. About your symptoms it happened the same with me, after a week or so i started to feel ill again, and in fact, i am still h pylori positive.
ranitidine is not PPI. So you can take it until the night before breath test.
here is a guideline on how long you should stop the drugs before breath test.
Hey, thanks for the pdf. Looks like I stopped taking them at the right time then. Just got to wait 2 weeks for my results nowHelico_expert wrote: ↑Fri Mar 29, 2019 7:14 amranitidine is not PPI. So you can take it until the night before breath test.
So an update from me.
Went for the breath test and it came back negative. However my stomach ache continued long after.
I was on ranitidine for another few weeks (which helped a little) before being switched onto lansoprazole from mid May. Seemed to stop my symptoms for a few weeks, but over the past week my symptoms have returned - bloating and a dull stomach ache round a 3/4 out of 10 on the pain scale.
My questions:
Can gastritis appear after HP eradication? This will now have been 6 months since I took the antibiotics. I'm scared these symptoms are cancer related. I'm 36 years old. From reading this forum it seems h.pylori enters the body when you're a child, meaning it's probably had a good few years to breed in there. More than long enough to potentially be cancer, right?
Can your body become immune to a PPI to make it stop working, or is this something more serious going on? I was on lansoprazole for 3 weeks with the triple therapy, then another month shortly after that when the symptoms returned.
My questions:
Hi how r you??
Any update?
Now you fine??
I have still stomach pain after first tripple therapy since 1 month.
Have more stress and anxiety about this horrible bug.
Any update?
Now you fine??
