If you are confirmed with H. pylori, in your convenient time, please help us with the symptoms survey that you are experiencing. Symptoms survey
helico4eva wrote:yes i can feel 1 cm small bumps under my skin between breastbone and navel
i asked couple of my Docs to check them and on physical exam they said its just fat
but sometimes under the bumps is stinging painful
A hard, tender knot or ball in the upper abdomen can be from trapped gas. This is a small collection of gas, usually in the colon. It is often associated with irritable bowel syndrome. The cause can be banal, such as an irritating food (you need to find out which foods irritate you personally) or anxiety or a combination of both. Passing wind or having a bowel movement sometimes help.
from next month i gonna start taking Omega3 (1000 mgx2), Fiber and Digestive Enzymes
gonna try throw everything at this bug
also one of my close friends told me he had gastritis a few years ago and it took him 3-5 years to feel normal again
another friend i talked to said it took him 2 years to heal gastritis...hes on PPI for 6 years now
from your past experience with patients how long does it take to heal gastritis and what supplements help fasten healing
Thanks a Tonne!!!
Speaking for myself.
Had infection, resisted once, pylera killed it.
Took me about 4 weeks to not feel awful after a meal ( i had pain in the duodenum before ), it was better since it didn't hurt as much as before but was far from perfect.
6 month to feel better but this period had ups and down
1 year to be normal again
Best advice i can give is to check if its truly eradicated ( don't hesitate to do the breath test twice in doubt ) and from then just be patient, don't stress and relax ( stress improves acid secretion so your ulcer/gastritis will take longer ).
Of course try to avoid alcohol ( yeah i know...) but don't spend money on all this crazy shit such as probiotics DGL and whatever...I work in webmarketing myself and i can assure you all of theses are almost all bogus ( like 90% ) I advise you to check john oliver videos on "studies" results it sums up the situation pretty well https://www.youtube.com/watch?v=0Rnq1NpHdmwtime card calculator .
Try to find foods that work good for you and experiment
Everyone's healing process is different, but it's important to be patient and give your body time to heal.
