Announcement:
Contact Admin Click Here
How is it possible to test positive for HP through blood test and negative when doing the biopsy from a gastroscope?
Moderators: Toni, barjammar
Bpositive
Genuine user
Post by Bpositive » Tue May 09, 2017 4:35 pm
I had blood work done for HP about a week before I received my appointment for a gastroscopy test and tested positive. During my procedure they took some samples and did a biopsy for h-Pylori which tested negative. How is this Possible I hadn't started the antibiotics until after the gastroscope test????
jhong721
Genuine user
Re: How is it possible to test positive for HP through blood test and negative when doing the biopsy from a gastroscope?
Post by jhong721 » Tue May 09, 2017 5:13 pm
You should do an Hpylori breath test. Blood test will only show that you were infected at some point in your life. Endoscopy isn't always accurate especially if they don't get a biopsy from the right area.
Genuine user
Post by Helico_expert » Wed May 10, 2017 1:47 am
it is true that blood test can only show history of infection. so, you may have taken some antibiotics recently for whatever disease and accidentally knock out H. pylori. Although this scenario is rare, it is not impossible.
Gastri biopsy test is quite accurate. Assuming that the Specialist did a CLOtest and a histology. If both tests came back negative, then you are almost pretty sure negative.
CLOtest can be wrong if you were taking PPI before endoscopy.
romano
Genuine user
Post by romano » Wed May 10, 2017 9:29 am
ok
ppi can false :
culture?
clotest?
histology?
Genuine user
Post by Helico_expert » Wed May 10, 2017 11:59 am
PPI can lead to lower acid, then other organism can grow and suppress H. pylori.
So with low load of H. pylori, it's harder to see in histology; lower UBT or stool test; and weaker CLOtest.
Hence, PPI can lead to false negative for all.
Bpositive
Genuine user
Post by Bpositive » Wed May 10, 2017 4:14 pm
Hi, and thanks for the response everyone.
I was on PPI for the blood test and the gastroscope.
How long does one have to be off PPI Mede to test for HP?
Genuine user
Post by Helico_expert » Thu May 11, 2017 2:05 am
Hi, here is a guideline how long each medication should be stopped before getting a HP test. Although this guideline is for UBT, it works for every other tests, except Blood test.
Bpositive
Genuine user
Post by Bpositive » Wed May 24, 2017 8:03 pm
Hi Heico_Expert, quick question? I just came back from my G.I. appointment today. Dr. has scheduled an HP breath test in 1 month from now.
Im supposed to be off my PPI meds for a minimum 30 days prior to my breath test in order to get an accurate test result.
I will be stopping my Tecta medication today but I'm still on DOMPERICONE MELEATE 10mg 3 times per day and Sucralfate 1000mg 4 times a day.
will this affect my results?
Genuine user
Post by Helico_expert » Wed May 24, 2017 11:05 pm
have a look at this guideline. Domperidone is fine. But the sucralfate will have to be stopped 14 days prior breath test.
Bpositive
Genuine user
Post by Bpositive » Thu May 25, 2017 10:43 am
Thanks Helico_expert
What about the Probiotics and the super enzymes?
Is that still good to keep taking?
Return to “Diagnosis and Testing”
