Announcement:
Contact Admin Click Here
Where to do the breath test
Elle86
Genuine user
Post by Elle86 » Thu Apr 17, 2014 11:41 pm
    do you need to go to a GI specialist to do your breath test or can you get it done at any lab?
    Genuine user
    Re: Where to do the breath test
    Post by Helico_expert » Sun Apr 20, 2014 8:06 pm
    you may go any local GP to get the test done.
    artmuz36
    Genuine user
    Post by artmuz36 » Mon Dec 12, 2016 3:14 pm
    Thank you! I just needed that information!
    MyCVSHR
