Announcement:
Contact Admin Click Here
need help i have hp
NADIABYAZ1982
Genuine user
need help i have hp
Post by NADIABYAZ1982 » Wed Jun 19, 2013 4:12 pm
Pls doctor i have hp and Gastritis i take many medecin my doctor gave me medecin 2 traetments first is oedes 20 mg 1gel 2times 5 days and Aximycine 1000 g1gel 2times 5 days and when i finished all ths medecin i take other treatment oedes 20 mg 1gel 2times 5 days and Zeclar 500 mg 1gel 2times 5 days and flagyl 500mg 1gel 2times 5 days but ths last treatment i stop take it after 2 days n again tried to take i want know if will be not éfficace after ths stoped and i tell ths to my doctor but he said if i stoped i can take now only medecin oedes and beviran fort ths medecin will not Elimination hélicobactére pylori n still take it n feel paining so much it mean bactérie hp still live in my estomack what can i do pls pls tell me any medecin can i take it and i hear if i take Herb called Liquorice kill these hp
Genuine user
Re: need help i have hp
Post by Helico_expert » Thu Jun 20, 2013 1:38 am
nobody knows if your stopping for 2 days will work. I guess since you already got the drug, you should continue to finish it. may it will work. after that, you'll need to stop your oedes for 3-4 weeks and do a breath test to check if you still have H. pylori. if still positive, you can try other antibiotic combinations. Talk to your GP about this paper below. See if he has access to any of the antibiotics.
original article
http://onlinelibrary.wiley.com/doi/10.1 ... 532.d03t03
supporting document with treatment plan
http://onlinelibrary.wiley.com/doi/10.1 ... 9/suppinfo
