Positive Stool HpSA but Negative UBT??
Posted: Tue Apr 14, 2015 2:55 pm
Was ordered by my doc to a gut test as she suspected it was functionally poorly (I was having problem raising my FT3 levels with meds for my Thyroid problem, so she wanted to check if its due to poor absorption in the gut). Test came back with positive H Pylori antibodies from the stool sample, so she had me take a UBT to confirm (which came back negative). I was not on any antibiotics or meds (except for my Thyroid condition with the doc said was fine) 4 weeks prior to the UBT so it should not have given a "false-negative".
I do not have or suffer from any of the reported symptoms, so my doc concluded that I DO NOT have H Pylori since the UBT came back negative. She explained that the detected stool antibodies were probably due to an old infection (not active) since UBT did not detect any.
Is that correct??? I've been reading up a lot on H Pylori and I'm just confused with the Positive HpSA with Negative UBT results. I read that positive HpSA in stool means ACTIVE H Pylori, which is more accurate than Serum antibodies (which cannot differentiate between old or new infection). Which is true then, the HpSA or UBT?
Anyone can shed some light on this?
