Announcement:
Contact Admin Click Here
HP FROM FRANCE
Moderators: Toni, barjammar
Romano02
Genuine user
Re: HP FROM FRANCE
Post by Romano02 » Sun Apr 30, 2017 9:18 am
Hi
i see you have right, test endoscpy is wrong in PPI treatment
I m disapointed that my specialist ( he says that not important) incredible!!!
I do the test UREA (14 days) :) the Tuesday 9 MAY
IN French ranitidine is note FREE SERVICE, just doctor can give that
Have you a other ANTI H2 ?? How many time, i should stop anti h2 before test ( 48h?)
For moment i take MOXYDAR (how many time , i should stop MOXYDAR before test ?
I have many pain after eat ( stomach chest and throat pain) I have stopped the first treatment antibio (détails in forts post) the 5th APRIL
i RESPECT DATE
THANKS THANKS
Apres la pluie, le beau temps arrive
FRENCH Proverb, translate :)
Romano02
Genuine user
Re: HP FROM FRANCE
Post by Romano02 » Sun Apr 30, 2017 9:58 am
An other question
I dont understand : after endoscopy (2 hours after) the specialist say me test HP is negative , It s very fast decision!!!!?
And after he says: "i HAVE DO many biopsy in the stomach for laboratory !
I dont understand : there a different test in endoscopy ????
Can you explain me ?
THANKS
Genuine user
Re: HP FROM FRANCE
Post by Helico_expert » Mon May 01, 2017 3:54 am
Apres la pluie, le beau temps arrive. Beautiful proverb.
You only need to stop H2 blocer for 6 hours before the UBT.
The biopsy test that your specialist did is called CLOtest. You'll get result within 10 minutes.
More biopsies are taken to the lab for histology and maybe bacterial culture. Histology will tell the doctor the level of inflammation and bacterial culture will tell the doctor what antibiotics you should be given.
Then again, PPI (such as omeprazole), can cause false negative in CLOtest and culture. Histology may not see bacteria, but can still see inflammation.
ivette.carlier
Genuine user
Re: HP FROM FRANCE
Post by ivette.carlier » Tue May 02, 2017 8:59 am
May God bless you doctor, even if some people will say it's your job to help people in need. I can clearly feel how satisfy is the patient you give answers to his trouble. Thank you so much.
________________________________________
http://www.montpellier-bs.com/international/
romano
Genuine user
Re: HP FROM FRANCE
Post by romano » Tue May 02, 2017 9:30 am
hi it s romano02 i have a problem with my first email
i create a new login.after i supprim the first
i m agree with you yvette . thanks To doctor
i think he his a realy specialist
Any question expert:
you know i do a endoscopy with ppi 7 days ago. stomach are ok no ulcer.
i have stop ppi for 7 days. And my stomach, throat and chest Burn!!😠. it possible to have an ulcer in 14days?
for c13 urea
the instruction of french labotory suggest stop ppi AND H2 blockers. ok for ppi but for h2??
last question
on french website helicobacter.fr gefh
the assemble of 2017 explain, they are a new type of HP the helicobacter caesarodunom
what do you think about ?
romano
Genuine user
Re: HP FROM FRANCE
Post by romano » Tue May 02, 2017 9:41 am
caesarodunum
Genuine user
Re: HP FROM FRANCE
Post by Helico_expert » Wed May 03, 2017 1:17 am
It is important to control your acid before your throat get burnt and becomes complicated.
The ulcers can come back if the acid is not control well.
H2 blocker can be used until the night before C13 breath test. So you should continue to take H2 blocker if you plan to repeat your breath test. If you dont want to repeat your breath test, then you should take PPI (talk to your doctor about increasing dose, or change to Rapeprazole).
Dont worry about other species of Helicobacter, treatment wise, they are all the same.
romano
Genuine user
Re: HP FROM FRANCE
Post by romano » Wed May 03, 2017 7:16 am
ok i plan To do my breath test 9th may.
On this date: I will be at 15 days without PPI or h2 blockers and 34 days without antibiotic....
Everything is ok ??
Genuine user
Re: HP FROM FRANCE
Post by Helico_expert » Wed May 03, 2017 2:17 pm
yup, that would be fine. But you can have some H2 block to control your acid.
Bpositive
Genuine user
Re: HP FROM FRANCE
Post by Bpositive » Wed May 03, 2017 5:23 pm
Hello everyone, I recently tested positive for h Pylori and have been on triple antibiotics for 5 days now. I'm also on Tecta PPI. My salivia is fuzzy bubblie and dry at times. My Tip of tongue is still soar at times and my throat is soar. I can taste bitter every so often through out the day.
My question is ? Does h Pylori cause these symptoms?
Also is anybody taking probiotics and enzymes while on the antibiotics ?
Thanks for your time.
Return to “Diseases and Symptoms”
